LT1 injectors
Old 04-15-2011, 10:23 AM
00silverGTP's Avatar
Default LT1 injectors
are they all the same? Have a buddy that needs inj in his 93. he just wants oem replacement.
Old 04-15-2011, 10:28 AM
LSWHO's Avatar
I think there's two different ones. I'm not sure.
I doubt you'd have problems swapping either one in though. They are close enough that the tune can compensate.
Old 04-15-2011, 10:40 AM
93M6Formula's Avatar
I know for sure that 93 Injectors are 22lbs compared to 94-97s 24lbs Injectors. Not sure if it is a problem to switch them or not though.
Old 04-15-2011, 10:42 AM
93Z2871805's Avatar
You can put later 24lb ones into a 93 with no issues.
Old 04-15-2011, 11:40 AM
flame's Avatar
Providing they are adjusted in the pcm
Old 04-15-2011, 11:48 AM
so will 98 inj work?
the 93 are 22lbs, anything over that will need tuned?
Old 04-15-2011, 11:58 AM
boostedlt1's Avatar
98 (ls1) injectors are 28lbs
they're also rated at about 10psi higher fuel pressure
Old 04-15-2011, 11:59 AM
Lawhead's Avatar
I got stock injectors i can sell
Old 04-15-2011, 12:03 PM
for a 93 lt1? how much?
Old 04-15-2011, 12:08 PM
happysem's Avatar
Will all LS injectors work?
Old 04-15-2011, 12:37 PM
Lawhead's Avatar
Off a 96 youll have to ask around here im almost 100% sure they will fit
Old 04-15-2011, 01:20 PM
moehorsepower's Avatar
Close, they are rated around 15lbs higher so
28 LB LS1 injectors comes out to around 24lb in an LT1
Old 04-15-2011, 04:56 PM
96capricemgr's Avatar
I thought the 93 ECM did not remember what it had "learned" like the 94+ PCMs meaning if you put 24lbs injectors in it without a retune you are going to be a fair bit too rich till the engine and unheated O2s finally warm up and take control. Best case there is you will wear the engine like it had a carburetor on it. I might fool around with a 2lbs difference on the later pcms for a short term fix since they do learn and have heated O2s that react faster but on a 93 no I would not.
Old 04-15-2011, 05:11 PM
LSWHO's Avatar
That would make sense with SD.
Old 04-15-2011, 05:16 PM
93Z2871805's Avatar
When you say "wear the engine like it had a carburetor on it," are you talking about washing the cylinder walls due to a rich condition?
Old 04-15-2011, 05:25 PM
Till it warmed up each time and the O2s became active, yes that is what I mean.
Old 04-15-2011, 06:53 PM
93Z2871805's Avatar
Okay, I could see that, but I could imagine it wouldn't be catastrophic wear (for a short period of time anyway, or if you did the heated o2 conversion).
Old 04-15-2011, 06:57 PM
LSWHO's Avatar
You'd be surprised how rich it can make you. Especially if the tune is already on the rich side.
Old 04-15-2011, 07:19 PM
93Z2871805's Avatar
Lol, I know all about rich, I had no O2s at all for about 2-3 weeks because the previous owner cut them out and plugged the headers (I still to this day can't understand why).
OP You can move up to 24# injectors, but you'd need a good tune. As stated above, with SD and non-heated O2s you'd run rich.
Quick Reply: LT1 injectors
