Oil pressure dropping to 0 on hard turns
Any suggestions as to what the problem might be? The oil level is 6 quarts. Every time I take a hard turn the oil pressure drops to about 20lbs, or if I take a really, really hard turn to the point where all 4 tires are screeching and sliding, the oil psi goes to 0 and remains there for about 2 seconds after straightening out. Not good when you are at 3000 rpm's. I have the Canton 242-T pan/pickup & a Melling 10554 with the pickup bolted on. Is it possible the pickup fell off?
the bolt could havebacked out, then the pick up would be soon to follow. The canton pick up is a tight fit inside the pan but can fall off if the bolt backs out. I also think the pick up may have fallen off.
