Name this LT1 noise
Name this LT1 noise
Sounds like an exhaust leak in person, sounds like something internal on video.
What do you think?
Exhaust note seems completely normal, running on 8 cyl.
Ideas?
http://youtu.be/YdCiFYMO1g8
What do you think?
Ideas?
Sounds exactly like the noise mine was making before I threw a rod bearing, stacked another rod bearing, and had two lifters go out. I'm pretty sure it was just the lifters. This was what it sounded like after all that.
http://www.youtube.com/watch?v=LkHwf...e_gdata_player
loose rocker, or those cheap *** header gaskets leaking the ebay headers come with. Mine started to leak just a few days after install. went to Mr. Gasket Ultra Seal header gaskets after and there still holding on strong 10k+ miles later.
Village Troll
Perhaps three different possibilities
loose rocker
loose spark plug
exhaust leak
The way to quickly dismiss if it's an exhaust leak is to put the trans in a high gear and accelerate. If the sound gets louder then it's most definitely an exhaust leak. If not then most likely the other two options. As stated, if not an exhaust leak, get a stethoscope and try to isolate what cylinder it's coming from.
loose rocker
loose spark plug
exhaust leak
lol i had an exhaust leak and figured i might as well put headers in if im gonna be in there anyways.. went to unscrew a plug to get the header by and it was a couple turns from falling out. tricky little bastards
I think you mean always use anti-seize on spark plug threads.
