Turbo Impala predictions!
Come on yall!
I need some predictions for my 95 turbo impala.
I'm gettin the car dynoed next wensday and I'm wonderin what some of u dudes think this thing is going to put down.
Setup- 355, stock cam, 1.5 summitracing RR, 96 camaro heads, gasket matched, bowl blended, manley tool steel springs, speed pro pistons (9.7:1 compression).
58mm professional products throttle bodie, ewp, walboro 255 w/hotwire, 42lb ford injtrs.
60mm garret from hp performance (they sold me some knockoff), .70 a/r compressor, .96 a/r turbine, p trim wheel (dont remember the number specs),
TTI hotside, 3" v-band downpipe y'd into dual 2 1/2" over the axles, 44MM tial wg w/10lb spring, Forged BOV, Forged mbc and SSautochrome 3" core 2 1/2" in/out intercooler.
Throw me some numbers!
my completely stock 147k mile lt1 put down 397whp @ 7psi. i don't see why you wouldn't break 400. i would've broken 400 if my tune was good, i found out on the dyno it was off then got it tweaked and it runs a lot better now
Those r some encouraging words. I planned on swapping the turbo if I didnt break 400.
We shall see!
