94 LT1 with 98-02 front end, question on LS1 lid
Does it still require all the work for the radiator and leaning them back? Was there a difference in radiator support between the front end changeover? I would like it to be one of my first mods, but not sure how to proceed with the front end swap.
You have to drill and tap for two bolt holes and either modify the lower base of the ls1 radiator support or flatten the core support for the base to sit flush like it was designed to be. The core support on the lt1 is raised were the ls1 core support is flat. Mine has this conversion so I speak from experience.
