PA Racing K Member. motor mounts?
Old 04-21-2011, 07:42 AM
blakez28's Avatar
Default PA Racing K Member. motor mounts?
My pa racing k member just came in about a week ago. This weekend i'm going to install the k member along with my longtubes. However from what I've seen from other k members it looks like it's missing the tubular part where the motor mounts connect to. Am I wrong? anyone running a pa racing k member?, and if so what motor mounts did you decide on?
Thinking about going with solid motor mounts if I could, and I've read the threads on the poly vs motor mount issue. I don't mind a little shake and i think i'll like it after the cam swap.
Old 04-21-2011, 08:10 AM
speedracer2536's Avatar
You use the stock pedestals from your old kmember
Old 04-21-2011, 08:32 AM
97REaper's Avatar
im using it. just use your stock mounts
Old 04-21-2011, 08:39 AM
blakez28's Avatar
Whew that's a relief then. Thanks alot guys. Have any pictures of your installs?
Old 04-21-2011, 04:06 PM
BOLO's Avatar
FYI, Madman sells a nice solid motor mounts that will bolt on to your PA Racing k member.
Old 04-21-2011, 04:43 PM
AirborneZ28's Avatar
Mine isn't a PA it's a UMI but they look similar so here are some photos if you are interested.
There are a few other photos if you are interested in my photobucket albumn:
http://s2.photobucket.com/albums/y9/...0Camaro%20Z28/
Old 04-21-2011, 04:45 PM
sorry the photos are so big. Is there any way to change the size that they appear here in the forums except for resizing them in photobucket before you post them?
Old 04-26-2011, 10:47 PM
blakez28's Avatar
Thanks for posting, and that comparison shot of the stock k member is awesome.
off topic but I was just at fort benning in charlie company for airborne school, last year
Old 04-27-2011, 12:56 PM
blakez28's Avatar
Compared to this?
Old 04-27-2011, 04:24 PM
madhatter's Avatar
The UMI setup only uses one pedestal while the PA uses both. No difference in function really, just different design.
Old 04-28-2011, 09:18 AM
blakez28's Avatar
How do you know this??
quote from madman email
"Our solid motor mounts will not work with that particular k-member. Looking at your picture you sent with the e-mail, it looks like there isn't a place to mount the driver's side motor mount."
Old 04-28-2011, 09:25 AM
blakez28's Avatar
So you're saying I need to use both stock pedestals?
What motor mounts can I use??
prefer solids if I can find them
Old 04-28-2011, 11:47 AM
white ghost's Avatar
My only question and thought in this whole thread is. What charlie you slicing with your rambo knife in the first picture? Lol
Old 04-28-2011, 04:09 PM
blakez28's Avatar
someone had to say it i guess.
Any more thoughts on this k member and what mounts to use? stock pedestals with poly mounts seem to be the way to go.
Old 05-01-2011, 07:41 PM
blakez28's Avatar
bump for more advice.
I'm so torn about using madman solid motor mounts. Common sense would tell me that because his solid motor mounts work with a stock k member, and because the pa k member uses the stock pedestals...then both of them should fit together. Am I missing something here?
I've heard madman tell some people it works but then he tells me that it doesn't. Why isn't just a definite answer?
Old 05-02-2011, 02:22 PM
blakez28's Avatar
Jason from pa racing said that these solid's should work so I'm going to try them out. Anyone else running this set up? poly tranny mount recommended with the solid motor mount correct?
Old 05-02-2011, 02:30 PM
i run it and they fit.. And yes use a poly tranny mount AND torque arm mount
Old 05-02-2011, 07:41 PM
blakez28's Avatar
You run with pa k member, and madman solid motor mounts?
any part number for the torque arm mount i didn't think about that
Quick Reply: PA Racing K Member. motor mounts?
