Loose the OPTISPARK forever
I had a post in the past about this mod, well the intake is now finished and getting ready to drop the LT1 into the truck, here are some pictures of the mod
http://www.flickr.com/photos/tinbend...in/photostream
http://www.flickr.com/photos/tinbend...n/photostream/
this is going to be ran by a '411 LS ECU, If anyone is interested I can provide contact info
"trilkb cool man, well done...reminds me a bit of my old trans am GTA"
actually it is a '96 WS6 Ram Air Bird long block
"96TransAmboosted i like the work. Did you buy or make the front cover for where the opti WAS "
well It is the stock cover with a 2.88" Dorman freeze plug fits perfectly with about 0.02 interference, and ultra silicone.
"Paul Bell Looks nice! You've had to add a crankshaft reluctor and sensor?"
'96 Already had the 4X reluctor
robsquikz28 your running a 96 timing cover with the crank sensor correct? yes sir "stock"
merim123 i think this is the vortech truck setup no? so you can use the 4x 96 signal and the 1x from the dizzy you put on? assuming you are blocking the opti with one of the covers that gm sells.
GM has a cover set up like this??? the distributor is a Vortec unit, basically everything except the long block and the ECU is Vortec, ECU is LS series
I could run coil per cylinder if i wanted but I have made enough mods already. and see prior comment on the cover
I did have a Tuned port motor in the truck, got about 500 miles on a $2300 motor when the water pump failed, and fried it all.
go here to see it
hopefully will get more out of this one
go here to see it
EXACTLY what I am doing, it has been programed for my setup, the '411 is so versital, if you can get the sensors on it, you can program the 411 to run it, way cool man!!!
heck man we could put one on your monty and run FI
Ah! ha! it is done, the patient is now devoid of a heart awaiting it's new bigger, & badder heart, donated by a to young to die bird that suffered a fatal meeting. LOL
if my Dr. knew he'd have a canary, I suffered through the back pain and GOT ER DID, of course the son helped a lot LOL it took 3 hours to pull 16 bolts but I now am setting quietly and the bugger is out
I will start on the step by step after my surgery, on 4/29/11, I will be tied to the easy chair for 6 weeks, and will need something to do. I will get everything documented including the wiring and ECU programming. Cool???
with pictures ??? hopefully ??
this Is the Cheapest and most logical way to setup an LT motor, as far as I have found. the 24X system Is way cool but $$$$$, and the resolution difference between the 24X and the Vortec is negligible unless you are running quarter mile traps. someone straighten me out if I am wrong, but I believe that the 24X uses the LS1 type ECU, like my system uses? and the man that did my initial ECU program has made several of them for the LT's
Good luck,
Al
