Cooling Fan Question?
Old 04-23-2011, 06:37 AM
r0llz1104's Avatar
Default Cooling Fan Question?
Does anyone know if both cooling fans should turn on at start engine for a '93 LT1? Or does the primary turn on first and then Secondary when engine hot?..
please help, thanx
Old 04-23-2011, 08:50 AM
shbox's Avatar
The fans should not be on at startup (maybe you have a trouble code that is causing it?)
93s and early 94s have primary and secondary fans. The primary fan comes on first, then the secondary (if necessary).
http://shbox.com/1/4th_gen_tech2.html#cooling
Old 04-27-2011, 05:40 PM
r0llz1104's Avatar
Hey thanx for the heads up shbox! Hey was checking your website and seems u know a lot about these models. Question? My car won't go over 40mph, doesn't kick in third gear as I'm driving. Rpms go over 5k and it won't throw another gear. Its like its stuck on second. Do you know what might be causing this?
Old 04-27-2011, 06:37 PM
shbox's Avatar
Check for transmission trouble codes, first.
Old 04-27-2011, 07:36 PM
rich5368's Avatar
Sounds like the cars in limp mode for some reason.
Old 04-27-2011, 11:05 PM
r0llz1104's Avatar
shbox:
I checked for trouble codes with a paperclip as you had recommended before. All I get is dtc 12. No other code. Could this be that ECM bad?
Old 04-27-2011, 11:11 PM
r0llz1104's Avatar
But will do,
Does anyone know any mechanic that specializes in these cars here in south texas?
Old 04-27-2011, 11:15 PM
jlpz's Avatar
where in south texas?
Old 04-28-2011, 06:03 AM
r0llz1104's Avatar
I'm from Mission, Tx..
Down on the Rio Grande Valley
Old 04-28-2011, 06:10 AM
RamAir95TA's Avatar
Limp mode is a condition in which the PCM loses just about ALL critical inputs from it's sensors and is VERY RARELY experienced. I doubt this is the case here.
Old 04-28-2011, 10:29 AM
r0llz1104's Avatar
well that's good to know.
Old 04-28-2011, 07:39 PM
rich5368's Avatar
True good point. I just sounded like it to me with the shifting issues he was saying.
Quick Reply: Cooling Fan Question?
