Thinking about Purchasing LT4 hot cam...
I Can Get a Pretty good Deal on a Brand New LT4 hot Cam Kit...Cam Lifters Springs 1.6 Roller Rockers...Complete GM Performance Kit... How Well will this Work With a Stock Set of Heads...Basically Looking to Get my Car running a little Faster with out Spending a Bunch of Cash...
The kit works very well with stock heads, I made the numbers below with it plus all the normal boltons and good programming. The only problem with the kit is the springs, they are just adequite. I have since ported my heads and swapped out those springs for a set of crane 10308-1 springs.
If you are not too concerned with performance, it's a great cam. Excellent street manners and sounds pretty good too! Not saying it does not perform well, but there are way more better options out there. The hotcam also likes the sauce but then again, what doesn't
profrom rockers 130 from cnc motorsports SA NB
comp 503 camshaft 230 from anywhere
spring kit 250 good to .550
pushrods 30 7.2
felpro timing cover gasket 7
silicon 5
better performing and all around better parts than that hot cam. parts could be cheaper if you buy useded.
pushrods 30 7.2
silicon 5
