ABS delete minus line lock?
Old 04-25-2011, 04:21 PM
maxplusten's Avatar
Default ABS delete minus line lock?
Has anyone done the ABS delete without line lock using the Wilwood proportioning valve? Do i just run my front lines straight to the master cyl and put the rears threw the valve?
Old 04-25-2011, 06:54 PM
sweetbmxrider's Avatar
Yes, you use the proportioning valve for the rear line and run the front lines straight to the master.
