Radio, window & electrical problem?
When driving my windows & radio will cut out sometimes at the same time. When driving today they went out and came
Back on when I hit the gas. Possible loose connection somewhere? How do I go about diagnosing this and do these symptoms sound familiar to anyone ?
I blew the RAP (Retained Accessory Power) module on my car while trying to install the window fix and lost both my radio and power windows. While looking for a fix i discovered a few threads talking about your issue (intermittant cutting out of both) on newer model cars. 96+ cars have a BCM aka Body Control Module and there is a circuit in there that the solder joint goes bad and you have to open up the box and resolder the connection. i don't remember where the picture of the circuit was but try searching for it.
Never mind!!!
here it is
http://www.fbodyonline.com/how-to-fi...dio-and-locks/
any pictures would still be awesome.
here it is
I couldn't get the link to work but here is the same link.
I went to solder my bcm today and i had a hard time. Getting it out was easy but soldering the little points was difficult partly because i didnt have real tiny solder. I would suggest getting the smallest solder you can get at radioshack or somewhere.
