lt1 swap using painless system
anyone have pics of the engine harness using the painless system .i need pics of the coil and ignition mod wiring as the car i have some one has cut the harness up .
Why would you pay all that for a pcm you can't do much with when the LT1 pcm is hugely adjustable and the software is cheap. There is even a program I have not tried that is supposed to be free or $30 donation to get rid of the nag screen.
Rather than point out things wrong with it I would challenge anyone to come up with a decent reason to use it.
im tring to fix a problem with a customers car that he had some one else put in the painless system .so thats what i have to work with .thats why i want info .if you dont have any then so be it
