timing play, how much is too much? vid inside
pm sent. aside from robsquikz28's obvious bias lol (no pun intended), is the comp replacement as good or better than the gm replacement? and its the 3307 chain correct?
I thought it looked rather normal too for a stock timing set.
I installed a LT4 ED timing set and the chain was rather tight when it went on. I replaced the cam a year later and was amazed how much it did loosen up. Maybe half of whats in the video but I am gonna assume its normal.
x2. id like to know. even tho i bought the comp replacement. this to me is wayyy too much in my eyes, theres def a good few degrees of cam play here, which i cant see being right
i should add, i just searched alldatapro and i didnt see anywhere in there about timing chain specs/play
