changin gaskets, front seal is leakin oil,
hey guys so im changin the oil pan seal on the TA, and i was wondering if yall could think of anything else that usually goes along with it? i was thinkin of the timing cover and those gaskets as well... chime in and give me some suggestions...
LT1s didn't leak from the factory. Most new leaks I've seen are associated with prior replacements/installs not done properly. Before I took my engine apart for the first time I had a very small front main seal leak, but that was about it. Remember some of these cars are 18 years old, so the leaks you see can be applied to just about any 18 year old car.
.....LT1s didn't leak from the factory. Most new leaks I've seen are associated with prior replacements/installs not done properly. Before I took my engine apart for the first time I had a very small front main seal leak, but that was about it. Remember some of these cars are 18 years old, so the leaks you see can be applied to just about any 18 year old car.
I've had two of the four seals on the front cover leak, requiring replacement, and the rear main started leaking 2 years ago, causing me to have to drop the pan, pull the tranny, and replace that too. All told, I've replaced every gasket on the engine except the head gaskets....
well somethin a little different, i have oil droplets comin out of midway down on the timing cover bolts... so im thinkin may be a good idea to take a look, i still have less than 500 miles on the motor since the cam install, and all top end motor work, nothin leaked when i finished install and ran it, just the face that she has been sittin a little while seems weird to start a leak...? **** is drivin me crazy at this point!
I just finished changing the oil pan and front cover last week. It took a little doing, but if you've got the time to do it it's not really that hard, just takes time. I was able to buy a new front cover with the seals installed for around $60 to my door from amazon. I had the egr and air removed so it wasnt too bad to do the front cover. I also took the opportunity to put in a new water pump, 160 thermostat, and clean/seal up the opti. If you decide to replace the front cover feel free to message me if you have any questions. The nice part about doing it completely wrong the first time is now I know what not to do haha.
It's a double edged sword with these gaskets. If you only change the oil pan gasket and it ends up being something on the front cover, you'll have to be verrrrry careful removing the front cover to not rip the oil pan gasket. They share the oil pan gasket at the bottom under the crank. I was glad to do both of them at the same time just to know that nightmare is over with. Now I just have to do the intake and valve cover gaskets and I might have this leak chased down hahah. It did fix a LOT of the leak, now I'm down to a drop or two a week. Either way good luck!
I've got a homemade hub installer for sale if you need it.
