93 z28 wont start
93 z28 wont start
My camaro died while i was driving it on the highway at about 75 and all it did was crank after that . I replaced the opti the icm, coil and plugs and it still wont start it has good fuel pressure at 40 with a new fuel pump. Im getting spark in the cylinders but no gas i believe the injectors arent shooting i put starting fluid down the tb and it still would just crank. i scanned it and the only code was 12 witch is normal my security turns on for a second when i first put the key in but doesnt blink and just goes away. I dont know what else i can do any ideas could it be my key ?
yes all my fuses are fine including the ignition fuse , has compression and power coming off the opti, im starting to to think its a problem with my injectors it wont fire with starting fluid either so does that mean my computer is not letting my car start?
