Hard to shift into 1st, 3rd, 5th, and reverse. Ideas?
So I was driving my Trans Am to a car show today, and noticed it was hard to shift into first and reverse. Well when we we're all leaving, we all ripped ***** out of there. Well I was shifting and missed third, because the same thing started happening with it. I tried it again, and I missed third again. I started driving just normal. Not getting on it, and I have to slam it, and use some decent force to get it to go into 1st, 3rd, 5th and reverse. Was wondering if anyone had an idea on this. Hopefully it isn't something major..
Aftermarket shifter? If so, and if it has adjustable stops, sometimes the nuts back off interfering with the shifts. This would make sense if it was the top stop since it's all the top gears.
I'd post this in the man. trans section. possible culprits, air in the hydro & needs to be bled, excess play in the shifter(worn out), worn out throw out bearing or clutch, or worn out synchros.
and I would check them in that order
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
1 Post
/\ /\ x2 mine did the same thing. but said ummm **** you and snapped when i was running a 2k race and it ripped out on second gear needless to say that was the most expensive break ive ever had. but made my money back 3 days later when i pulled him on a new bronze internals to replace all the plastic ****!!!
or check the bolts holding your shifter onto the .... shifter lol. you should have 2 1/2 or 9/16 bolt heads holding the actual shifter on if they backed out and allowed play you might not be able to fully engage the shifter thus causing this problem. but you would notice a lot of play in your shifter.
I'll check some of these things out. Thanks guys, but as of this morning she's out of commission. Got it into reverse after fighting to slam it in, and it popped right out after like two feet, then fought to get it back into first. Its way worse than it was the other day.
Village Troll
its possible it could just be the cup, but how do you explain how it ONLY pops out of reverse, I wouldn't be surprised if the rev synchro is shot as well.
A Synchro Ring doesnt cause it to pop-out..worn out Keys & D-ring will cause it to pop-out. A Synchro Ring just matches the free-spinning Gear with the speed of the Input shaft/Counter Shaft at the time, hence the name, and the grinding when it's fucked up, or the Keys & D-ring are worn.
If the Cup is fucked off to the point where it will partially engage Reverse then that is his issue on why it will pop-out..the D-ring & Keys aren't fully locking out to hold the Slider on the Gear. Also there is Metal D-ring & Key Retaining Plate on the back side of the Reverse Slider Assembly, my stock T56 was cracked and that caused Reverse to pop out every now n then cause it wasnt letting the Keys hold the Slider in place.
