Coolant lines question
I swapped the radiator tonite on my 93 auto TA - there were two metal lines on the passenger side w/ 13mm fittings... What are they for? ...i noticed the lower one has a slight leak so can I delete it entirely and plug the holes?
TIA
TIA
If you have green coming out around it you might have cracked the radiator tank on that side from over torquing the cooler line.
