what do you guys think about this set up?
Old 05-14-2011, 07:48 PM
1slow94z28's Avatar
Default what do you guys think about this set up?
my motor is being put together by Karl Ellwein. ESE#33.
block:383
factory 4 bolt main
howards track smart crank
howards billet rods 6.0"
mahle power pack pistons
12.5:1 compression
heads: advanced inductions
200cc dominator LT1 CNC heads
26120 beehive springs
custom manley severe duty stainless pro flo valves 2.00i/1.56e
street/strip LTx intake manifold with port matched geometry
custom billet cam 242/246 .584/.584 108lsa
i have all supporting bolt ons.... let me know what you all feel about this combo
thanks
Mike
Old 05-14-2011, 07:50 PM
Camaroking1996's Avatar
That's gonna be a badass motor right there
Old 05-14-2011, 07:51 PM
coolmanvette75's Avatar
I think thats a strong set up!
Old 05-14-2011, 08:37 PM
97Z28SS's Avatar
Should be good for 460 -480 rwhp with an m6 and it should fly if you can get it to hook. Time to start saving for a better rear. My new engine has the exact same rotating assembly as yours and I'm looking forward to having some fun this summer, good luck with your setup.
Old 05-14-2011, 08:39 PM
according to his sig he has an s60, so he should be good as far as rears go...
Old 05-14-2011, 09:19 PM
robsquikz28's Avatar
high 10s are possible
Old 05-15-2011, 05:05 AM
1slow94z28's Avatar
Thanks for your input guys. This engine will be accomodated by a mcleod twin disc/billet steel flywheel combo and t56. I have a nitrous outlet plate kit going on aswell. 175 hit should be more than enough to get this car moving in full trim.
Old 05-15-2011, 06:48 AM
97Z28SS's Avatar
Don't forget the McLeod blowshield, better to be safe than sorry, but you definately have a stout setup.
Old 05-15-2011, 02:17 PM
1slow94z28's Avatar
Hopefully I can have the car together with some test and tune so I can attemp to run at the LTx shoot out
Old 05-15-2011, 02:59 PM
BOLO's Avatar
block:383
factory 4 bolt main
12.1 compression
thanks
Mike
That, right there, is an amazing combo
Old 05-15-2011, 06:08 PM
1slow94z28's Avatar
So far so good. I'm thinking about running E85. Any thoughts on that? Thanks guys
Old 05-15-2011, 06:14 PM
RamAir95TA's Avatar
I am running an almost identical setup with a smaller cam, so yours will undoubtedly fly! Great choice of parts!
Old 05-15-2011, 08:22 PM
Lawhead's Avatar
E85 seems to be taking the racing world by storm hear it gives some pretty good gains as well
If it was available here I would run it in the TA
Old 05-16-2011, 09:27 AM
1slow94z28's Avatar
From what I hear, E85 needs more injector than pump gas. I gotta do my research. Thanks again for all the positive compliments guys!
Quick Reply: what do you guys think about this set up?
