great, #6 cylinder is dead
So when I went to put in my new spark plugs all of them looked old except one...it looked brand ****** new.
never really got on the car much but when I did after 3k RPM it makes some god awful noise which ill try to put a video up of it soon. Any ideas on what it can be? New opti, wires, and plugs. Hopefully its just my injectors but just seeing if it can be anything else. Also takes FOREVER to start up.
start there....the god aweful noise you are hearing is probably detonation........so stop making the noise.....thats the easiest way to break the motor if thats the case
New head gaskets. If it was a head gasket wouldn't it always be sluggish?
and I checked my spark, #6 has spark. So now im gonna check fuel, ugh process of elimination sucks. Espically in the cold
Village Troll
If that cylinder is not firing it will always feel sluggish. If that cylinder is indeed dead then once this problem is fixed it'll be a night and day difference.
A lot of things you need to check before thinking it's a head gasket, and even if you have coolant leaking into a cylinder won't necessarily kill ignition of the fuel mixture.
Village Troll
Did you check fuel? As stated, take a broom handle or screw driver and put it against the fuel injector to hear if it actuates when the engine is running.
You can presurize your coolant system with a pressure tester which can be rented at any Autozone. Pressurize to 18psi max. See if pressure bleeds off right away. If it does bleed off quickly you have a real problem (however you have said nothing about missing coolant so...) Keep plug out of #6. If system does not bleed off right away, keep pressurized for a half hour. Rotate crank by hand (5/8" socket on the crank bolt will do just fine) and see if coolant expels itself from the plug hole.
No work done to the heads, just needed head gaskets.
and I haven't been missing any coolant at all. Never leaks anything actually. Lol only good thing about this car so far
Finally found my problem!!! It was fuel, took iff my intake and injectors, cleaned out the intake and took the injectors to midas to get cleaned up. They said they were definately clogged something fierce. So now to put it all back together, while the intake is off im gonna go ahead and delete the EGR and tune it out though. Should be done tomorrow thanks for all the help everyone, I really appreciate it
