Throwing some codes, help me out!
Hey guys I pulled some codes on my car and the ones it's thowing are
13, 26, and 71.
Can someone help me determine how to go about fixing them?
Thanks
13, 26, and 71.
Thanks
http://shbox.com/1/Dtcs.htm
Driver's side O2, EVAP canister purge solenoid valve circuit, AC evaporator temp sensor circuit...
Quad-Driver Module (QDM) #1 circuit
applies to:
- AIR pump relay circuit
- EGR solenoid
- EVAP solenoid
Probably AIR pump. Check the fuse.
Ok I see why I would have CODE 26, I deleted the AIR pump so im sure that's why that's going off. (kinda forgot about that)
I just installed brand new AC Delco Heated 02's and made the harness myself so im not sure why it would be throwing that code.
And im not sure what CODE 71 means exactly, can someone enlighten me a little bit?
