oil catch can question??
Does anyone make an oil catch can for a LT1? I see a bunch of universal kits but if I can spend a little bit more for one made for an LT1 it would make life eaiser.
Installed this one from WS6 store (made for LS1 - but mounts and works perfectly on LT1). Expensive I know, but took me 5 minutes to install and looks good too. Mounted it to my driverside head, behind the ICM mount and routed it to my PCV on the driverside many and the front of the manny.
http://www.ws6project.com/user_stor/...oducts_id=1787
It's pretty simple really, you just remove the metal tube between the PCV valve and the front of the intake manifold, and replace it with the catch can, using as much fuel line as needed to mount it wherever you want it. Here's some pics I took when i did it:
http://s158.photobucket.com/albums/t...3/Catch%20Can/
There's one pic with the parts laid out before assembly. Also the first pic in that album has nothing to do with the catch can.
