How to get egr out way
So im tryin to pull my driver side valve cover off how do I get the egr out the way so i can pull it off ? what will I need
There is no EGR in your way. You must be talking about the AIR piping. You loosen the rubber hose clamp and loosen the nut (7/8") going into the exhaust manifold, so you can remove the valve/pipe.
