Tune question
Sure they can start it. You should be able to drive it home also. BUT DO NOT GET DOWN ON IT until it's tuned.
You'll not want to run the car with red tops and a stock injector pulse.
but if you must take that risk, leave the factory injectors in it until the computer is set up for the larger ones. if not, you will wash out the rings and end up tearing it down for a fresh hone and a new set of rings (if it goes on long enough new bearings also)
