vacuum leak 97 camaro - LS1TECH
Thread Tools Search this Thread
Old 05-26-2011, 10:07 PM   #1
97'_Z/28's Avatar
Default vacuum leak 97 camaro
there is some sort of air leak around my throttle body that i cannot find. pulled the throttle body replaced some hoses but still nothing. has anybody had the same issue? any suggestions??
97'_Z/28 is offline   Reply With Quote
Old 05-26-2011, 11:19 PM   #2
LilJayV10's Avatar
Have you checked the throttle body gasket? There a few vacuum lines up there.
LilJayV10 is offline   Reply With Quote
Old 05-26-2011, 11:20 PM   #3
how do you know you have a leak at the throttle body? are you sure your not hearing the bearings in the alternator?
5_LTR_ETR is offline   Reply With Quote
Old 05-26-2011, 11:27 PM   #4
97'_Z/28's Avatar
i did the brake cleaner trick. and it came from under the throttle body. i replaced a cracked hose running from the intake manifold under the throttle body to the pcv valve. also replaced the throttle body gasket and cleaned the throttle body. but still no luck
Old 05-26-2011, 11:42 PM   #5
when i smoked i used to get a cigar smoking real nice and move it around the area at night time while shining a light on it. really easy to see where the smoke is being pulled in in the light.. im sure theres better ideas then that though lol. not sure what brake cleaner trick your talking about
Old 05-26-2011, 11:56 PM   #6
97'_Z/28's Avatar
you spray brake cleaner or starting fluid around the area you think you might have a leak and i will cause the the rpm to either drop or go up.
Old 05-27-2011, 12:00 AM   #7
DisturbedTA's Avatar
have u changed the iac gasket???
DisturbedTA is offline   Reply With Quote
Old 05-27-2011, 12:01 AM   #8
oh ok ya i forgot about that.
maybe a tear in the elbow? little hole or anything like that.. i know mines starting to tear a little right where it clamps on
Old 05-27-2011, 12:06 AM   #9
97'_Z/28's Avatar
no i havent changed the iac gasket. thank you. i checked the elbow and it seem to be fine.
Old 05-27-2011, 12:10 AM   #10
your welcome yeah check that and also mine is a 95 it has a tube in the intake under the tb it might be leaking also
Old 05-27-2011, 12:11 AM   #11
97'_Z/28's Avatar
were can i buy a new elbow??
Old 05-27-2011, 12:12 AM   #12
LilJayV10's Avatar
Quote:
I think you can use that intake for a bong too.
Old 05-27-2011, 12:20 AM   #13
id get an aluminum one from summit or ebay or w/e works best for you.
and seriously... how would you make the intake into a bong? lol
Related Topics
Thread Thread Starter Forum Replies Last Post
93 intake manifold questions. thundercat97 LT1-LT4 Modifications 4 03-05-2016 10:41 PM
throttle body boost leak User-c3 Forced Induction 4 08-02-2013 02:45 PM
throttle body question BallerCamaro21 LT1-LT4 Modifications 6 06-22-2012 06:58 PM
High Idle on Electronic Throttle Body trans_am_31 General Maintenance & Repairs 5 02-05-2012 11:59 PM
Tags
93, 96, 97, body, camaro, chevy, common, leak, leaks, lines, locations, lt1, ss, throttle, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
    Get answers from community experts
What's your question?
Send
