New motor build
The 10's NA will be tough. Two fellow B-bodies have done it with a similar LTX motor combo. They are completely dialed-in though, weigh 200-400 lbs less, and running higher gear ratios. I'd be happy with low 11's NA at 118-120 MPH at my current weight. Willl need winter air down here in the Tampa swamp for that trap speed. You know the drill. I remember you also.
flyinZ, see above on the current weight. Goal is to get down to 3950 this winter with me in it. I'd like to run 10's on the motor.
