Clickin, Tapping, Knocking? WTH is it
Im not sure if you can hear it on this video(most noticeable 14secs-19secs). Its not like its a loud obvious noise. I can hear it and the time in between tapping increases when I push the pedal. Ive done as much research as I could, so now I am posting.
p.s. This was recorded from my phone so the sound quality is iffy
http://youtu.be/MKk2vuqfW8A
*updated video* http://youtu.be/1IIs-XnzT3I
It doesn't sound like a rod but you never changed rpms on the motor.
Knocking is usually something deep in the motor going south like a rod or main bearing, piston slap or connecting rod issues.
Tapping is usually valvetrain issues. Rocker arm, lifter. Exhaust leaks can sound alot like a lifter or rocker problem.
Clicking could be an injector noise which may not be a problem at all.
Post the problem again with a better camera and change the engine rpm's so the problem is more audible.
I dont hear it much....I looked at youtube videos of lt1s knocking and it sounds nothing like that. I know its coming from the lower section of the engine. I can barely hear it under the hood
I've also herd that a leaking exhaust manifold can sound like a ticking noise.
.02
Yeah if it was a rod bearing stacked or a wrist pin problem there'd be little question. I noticed headers in your video, check the collector gaskets if the noise is more audible down there under the car. High temp Permatex copper sealant on the header collector. then a new gasket then more copper sealant on the exhaust flange should correct the problem.
Check your header gaskets. When I installed my longtubes and the paper gaskets that came with it started making a ticking noise, because they they burnt up. People on this forum thought it was a valvetrain tick but it was just the passenger side header gasket. I expected the worst, but it turned out to be not a big deal.
new video. Im thinking its an exhaust leak...but not sure... thanks for the help guys
Check the oil for glittery metallic bearing material just for piece of mind. Drain a little into a jar. Has the noise been getting worse? Watch for a change in the normal oil pressure range from before the sound started. Hope it's just an exhaust leak. But the rattle sounds alot like a rod bearing when the motor rpms are coming up from idle. Hope I'm wrong. At 16 through 22 seconds you seem to really be able to hear at off idle
