Scat I beams
Old 05-31-2011, 07:09 PM
Camaroking1996's Avatar
Default Scat I beams
Are Scat I beams a good choice for a 355 with forged pistons and a stock crank?
Old 05-31-2011, 08:15 PM
anyone?
Old 05-31-2011, 08:19 PM
nitrous2fast's Avatar
you might be more specific on which ones?
Old 05-31-2011, 08:31 PM
http://www.competitionproducts.com/S...uctinfo/SCR5A/
Old 05-31-2011, 09:58 PM
Low N Slow's Avatar
http://www.ellweinengines.com/Ellwei...Kit/355Kit.htm
Here's a link to a budget build, he uses Scat I beams but with 7/16 bolts.
Old 05-31-2011, 10:07 PM
Is there any real differences between a 3/8 bolt and a 7/16 bolt?
Old 05-31-2011, 11:22 PM
Hackscamaro's Avatar
i used the same rods only 6 inch. stock crank scat rods and mahle pistons. and ai heads and cam. the work perfect for a budget build and have never gave me a problem. only difference between a 3/8s bolt and 7/16s is the size and the bolts are stronger on the 7/16s
Old 05-31-2011, 11:26 PM
lt1-xjs's Avatar
Besides the 1/16" dia ? The rod with the 7/16 bolt is a stronger rod rated at higher hp. You"ll need to know what piston you are using also when selecting a rod. I'd follow the Ellwein link myself.
Old 06-01-2011, 06:20 AM
Thanks guys
Old 06-01-2011, 10:10 AM
speedracer2536's Avatar
I have those rods in my 355.. I am happy with them
Old 06-01-2011, 11:55 AM
RamAir95TA's Avatar
6" forged Scat I-beams in my 383 here...
Old 06-01-2011, 03:53 PM
RamAir what pistons are you running?
Old 06-01-2011, 07:00 PM
RamAir95TA's Avatar
SRP -5cc forged flat-tops for 6" rod.
Old 06-01-2011, 07:40 PM
Ok thanks and what is your fastest run with your 383?
Old 06-01-2011, 07:54 PM
RamAir95TA's Avatar
You can see my signature, can't you? Or do you post on your phone using the mobile site?
10.82@124.25, 1.43 60'
Old 06-01-2011, 08:05 PM
I'm on mobile right now but I've heard and seen your car on YouTube and it looks and sounds sweet
Old 06-01-2011, 08:27 PM
MattSapp95_T/A's Avatar
Scat I beams are good rods.... You won't have any issues with them
Old 06-01-2011, 11:37 PM
SS14PSI's Avatar
I have em in mine....no issues.
Old 06-02-2011, 09:36 PM
97Z28SS's Avatar
Get the ones in the Ellewin Engines ad I believe they are the Scat Pro Comp's which are 4340 forged with the 7/16 capscrews.
