Help please!!!!!!!!!!!!!!!!
Old 06-02-2011, 12:53 AM
J.love's Avatar
Default Help please!!!!!!!!!!!!!!!!
my 95 lt1 wont start new engine only a month and a half old, was going down the road and it just died, has not started up since turns but wont start
Old 06-02-2011, 01:07 AM
food nd cars's Avatar
start with the basics. is it getting fuel, air, spark?
Old 06-02-2011, 04:39 AM
strokeme's Avatar
^x2..took the words right out of my mouth! If you dont have spark, could be as simple as an ignition module.
Old 06-02-2011, 01:02 PM
J.love's Avatar
i have spark and great fuel pressure and it still wont run the guy i got it from just put a new engine and he SAYS that he was goin down the road and it just shut off now it wont crank up
Old 06-02-2011, 01:24 PM
gatorhead's Avatar
where did you check for spark? What was fuel pressure?
Old 06-02-2011, 03:48 PM
J.love's Avatar
the plugs and im not sure on the pressure but i just changed fuel pump,filter, and injectors
Old 06-02-2011, 04:13 PM
draggin97s10's Avatar
stupid question...does it have gas in it? Is the spark strong? I would double check all of your connections on the work your just did.
Old 06-02-2011, 04:18 PM
That's MISTER MODERATOR
Paul Bell's Avatar
it wont crank up
Is this engine cranking over but not starting?
Have you attached a mechanical fuel pressure gauge to the fuel rail test port (Schrader valve) and noted the pressure while cranking?
If it's cranking AND you have fuel pressure AND you have spark, it should start. Do you smell raw fuel while trying to start it? Are the spark plugs wet with fuel?
Why were the injectors changed? (Exactly) what fuel injectors are currently installed in this engine?
Quick Reply: Help please!!!!!!!!!!!!!!!!
