Stall converter
Old 06-02-2011, 03:29 PM
Shakerz1313's Avatar
Default Stall converter
Can someone explain this concept to me. I know(think) that when you have a 3400 stall for instance that the car is forced to lock up once the rpms hit 3400. I also know you can drive the car at less rpms than this. How do you use a stall converter to your benefit, i mean how do you unlock the drive train till it hits 3400 when your wanting to actually race it.
Old 06-02-2011, 03:33 PM
henry172's Avatar
http://www.badasscars.com/index.cfm/...d=78/prd78.htm
Old 06-02-2011, 03:39 PM
Thanks for link. Appreciate it. So if you are say at a strip and had a 3400 converter, you would rev the car just under 3400 with the break held down till the green?
Old 06-02-2011, 06:58 PM
transbird95's Avatar
Depending on how tight the stall is you most likely won't be able to brake stall it to its stall speed. For example I have a 4000 stall converter and I can only brake stall it to a little over 3000. My old converter was a 3400 stall and I could only foot brake it to 2200 or so. Most converters like to be launched off idle or with just a little rpm. Once you figure out what stall you need you will have to experiment with what works best for your car. Also don't cheap out with the converter i learned the hard way...... twice.
