motor swap
List of things you need to swap onto the 93 motor from the 96 motor.
Intake
Fuel rail
Throttle Body
Timing cover
Opti
Reluctor wheel for crank sensor(located behind the timing cover on the crank snout)
Balancer
Oil pressure sensor
95-97 cam gear (must be used to accept the opti your 96 has)
Cam shaft dowel pin must me adjusted to work with the 95-97 cam gear. (I can't remember the specs on that)
I think that just about covers it.
Intake
Fuel rail
Throttle Body
Timing cover
Opti
Balancer
Oil pressure sensor
