Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Electrical Guides
- Camaro and Firebird: How to Replace Ignition Coils
Step by step instructions for do-it-yourself repairs
Where Is The Coil Pack and How Do I Replace It??
Going to replace coil pack on my car 1997 Red Formula WS6. Where is it?? How do I replace it?? I don't know much so please dumb it down for me.
It's on the driver's side of the car, bolted to the front of the engine, underneath all the ducting that lets air into the engine. Disconnect the negative battery cable, then take the ducting off (take the hose clamps off and then separate near the mass air flow sensor), then unplug the wires from the coil (ICM wire, coil wire, and coil spark plug wire), then remove the bolts that hold the coil to the head.
Make sure to put the grounds back on when you put the new coil on.
Here is a picture of the coil. Yours is probably black and has one less connection though:
just got done got the coil for 25$ took 30 mins total from beginning of taking things off to starting engine up again. now iam goin to the inn of the dove with my fiancee in the bird laterrrrr!!!
