Aligning k member when reinstalling
Hi there
I am reinstalling my engine/ trans/ k member back into my car. I have the body back down on the k member which has the engine and trans. I have 4 of the 6 bolts in the k member most of the way in, 1 at all 4 corners and both studs of both shock towers have nuts on them. The problem I am having is the engine and trans are not straight in the body. The trans is off center of the transmission hump by about a inch or two and is close on the passenger side. I cannot align the transmission cross member. I have the car on jackstands in the front, and on ramps in the rear. Should I jack up the k member and get pressure off the 4 bolts, then try to pry the transmission to get the trans cross member to align ? Or is there another way of doing this. Please let me know what you can advise me on this.
tia
andy schuck
tia
andy schuck
