LT1 Starter wiring probems
Old 06-07-2011, 09:09 PM
BigBlockPwr's Avatar
Default LT1 Starter wiring probems
I have two small wires coming out of the same harness near the starter. One of them is connected to the small post on the starter. The other small wire is black and is just hanging there. My alternator suddenly stopped charging and I assume that wire has something to do with it but I don't know where to connect it. If I rev the engine the guage shows 13.9. When I let off, it falls to 8.
I have a 1997 Trans am lt1 6speed. Stock starter.
Old 06-07-2011, 09:12 PM
Wicked94Z's Avatar
it's a pcm ground.... attaches to the block.
Old 06-07-2011, 09:22 PM
The cars starts fine but the alternator is not charging. If that wire is not grounded, will it cause the alternator to not charger?
Old 06-07-2011, 09:24 PM
Here is the wire
Old 06-07-2011, 09:26 PM
whytryz28's Avatar
Get the alternator tested.
another view
Old 06-07-2011, 09:28 PM
It was all fine until I took the starter off and found this wire hanging there above the stater. I put the starter back on and all of a sudden it stopped charging. The alternator is fine.
I didn't even disconnect any of the wires from the starter. I just dropped it to fix my dip stick.
Old 06-07-2011, 10:23 PM
ZFreie's Avatar
Can you see where it goes? I do agree with wicked about it looking like a ground.
Old 06-08-2011, 08:28 AM
I think it's a ground but I'm not sure. I have no idea where is goes? It was tucked up about the starter and when I dropped the starter, there it was.
If it is the PCM ground, will that effect the alternator charging?
Old 06-08-2011, 10:26 AM
ZFreie's Avatar
Not having a ground connect could do all kinds of crazy things lol Hook the ground back up and see what happens...
Old 06-08-2011, 02:15 PM
qc97z's Avatar
Start the car, and tap that wire/eyelet to ground. If you get a nasty spark, it's a hot wire and not a ground wire. If you get nothing, bolt that sumbitch down.
Nice exposed wiring on the starter solenoid BTW. Wrap that $hit up.
Old 06-08-2011, 02:51 PM
WS Sick's Avatar
purple wire starter black wire lug on the block just below the head.
Old 06-08-2011, 02:54 PM
ZFreie's Avatar
Much better idea. I think I have a new way of testing unknow wires now quickly
Old 08-01-2012, 10:19 PM
criticalx's Avatar
whats the black and blue plug for?
Quick Reply: LT1 Starter wiring probems
