I has lid now
Old 06-10-2011, 12:36 PM
speed_demon24's Avatar
Default I has lid now
Just need to extend the IAT and MAF wires and I'm done. Going to wait for it to cool off a bit so that's coming tonight. No trimming was done on the hood or car.
Old 06-10-2011, 12:37 PM
draggin97s10's Avatar
Looks like a clean install. Nicely done
Old 06-10-2011, 12:42 PM
Badazz 97 TA's Avatar
where did you get that rubber connector elbow piece? (from the TB to the MAF)
Old 06-10-2011, 12:45 PM
http://intakehoses.com/Merchant2/mer...gory_Code=RHH8
Old 06-10-2011, 01:00 PM
riceburnerZ28's Avatar
Looks like a clean install. Did you have to modify anything to make it fit?
Old 06-10-2011, 01:07 PM
Just had to trim the bottom of the radiator support since the LT1 and LS1 core supports are different.
Old 06-10-2011, 01:18 PM
MonmouthCtyLS7's Avatar
Cool now all you need is the LS1 and you'll be all set
Old 06-10-2011, 01:29 PM
Shakerz1313's Avatar
That looks sharp! I have a nice kN Filter set up but man its a pain in the **** to clean the filter. Have to remove the bottom valance. Might look into getting one of those.
Old 06-10-2011, 03:07 PM
GREGG 97Z's Avatar
Looks great, your going to see a big difference in throttle response, I was really surprised by the difference. What type of hood?
Old 06-10-2011, 03:10 PM
munsterz28's Avatar
what hood are you running if it just cleared?
Old 06-10-2011, 03:22 PM
trufiber 3" cowl.
Old 06-10-2011, 03:45 PM
Could the lid work with a sunoco hood?
Old 06-10-2011, 04:16 PM
SS MPSTR's Avatar
Would love to see detail underneath. The hood you have must have enough material at the lid area raised to form the cowl...not likely to work on any other hood type (?)
Old 06-10-2011, 04:27 PM
The cowl goes all the way to the hood latch so other hoods would require cutting.
They have underside pics here.
http://www.trufiber.com/PhotoDetails...=TF30020-A49-3
Old 06-10-2011, 04:49 PM
Tireburnin's Avatar
I look forward to your results. It will be hard to compare A-B, but I have a feeling you will notice a difference and see a gain.
Old 06-11-2011, 06:58 AM
97pontta's Avatar
What brand of CAI did you run before?
Old 06-11-2011, 11:19 AM
Lingenfelter with 1le elbow.
Just took it for a quick drive. Hard to feel SOTP but it definitely sounds quite a bit throatier/louder at WOT.
Old 06-11-2011, 11:54 AM
AChotrod's Avatar
Get a Chris1313 ram air for it and I bet it picks up about .2 & 2mph at the track. Almost every car Ive seen do those mods to has gained about that.
Old 06-11-2011, 11:56 AM
I would hydrolock my car the first time it rained....
Old 06-11-2011, 12:03 PM
AChotrod's Avatar
Im pretty sure it comes with a block off plate for DDing the car. At least my SLP one did on my LS1 Formula
Quick Reply: I has lid now
