New build under way.
#61
I see a couple of you guys seem to like the21* trick flows. Over stock with both heads fully ported how much HP will the tfs make over the stock ones? Or in the real world what kinda time differences?
#62
Im not sure on time diff or dyno numbers. From wat i seen they flow bout 20-30 cfm on flow bench. There are lot more that goes into track times then flow numbers. I dont know if any ones got any times on the swap yet.
