missing after 5000 rpms!!!
Old 06-16-2011, 03:34 PM
speedZ28's Avatar
Default missing after 5000 rpms!!!
I have a 96 lt1 camaro!! It just started last nite will do it from 5000 to 6000 win it shifts into another gear!! I out new wires and plugs and the cap and button on the last motor witch it wasn't on there that long and bows it on my 383 iv been ******* the **** out of it so I guess its probly the cheap *** button and cap butt if u have ne other pointers that would be great thanks guys
Old 06-16-2011, 05:02 PM
LSWHO's Avatar
Check for arcing in the wires especially around the coil.
Old 06-16-2011, 06:15 PM
speedZ28's Avatar
K thanks
Old 06-16-2011, 11:52 PM
86zboss's Avatar
Is it a continuous miss like a rev limiter or missing here and there above 5k? Could be Opti or maybe coil. How old are the plugs?
Old 06-17-2011, 12:24 AM
SR_94Blackbird's Avatar
Are the wires snapped snug on all the plugs and on the opti terminals? Are the wires touching anything hot? Did you gap them properly? Maybe you broke a plug and you didn't know it?
I'd double check all of that, even double check the plugs too to rule out all of that. It took me a couple hours to route all my new wires away from anything hot. Then I'd look at the coil and ICM.
No offense your talking in slang, but did you say you replaced the cap in the opti?
Old 06-17-2011, 08:31 AM
Village Troll
SS RRR's Avatar
If it's smooth and starts missing at those rpm levels I would suspect the rotor screws in the opti are coming loose. I had that same problem, opened up the opti and found this:
BTW... it's rpm. Not rpms.
Old 06-17-2011, 10:28 AM
speedZ28's Avatar
I'm sorry guys for talking slang lol!!! But first build and little upsetting win stuff doesn't go rite no wat I mean lol!! Yes its smooth all the way up too 5000 (rpm) lol!!! And it starts banging and popping all the the way up to 6000 ( rpm) !! It just after 5000 win it does all this mess? And yes I changed the cap,button its not that old but ill check all the plug wires and plugs and the rest of the goodies tonite before race Saturday if u guys have nething else to add would be great thanks!!!
Old 06-17-2011, 10:30 AM
speedZ28's Avatar
Oh and yes win u get over 5000 or bout there its like a rev limiter going to 6000 then goes back down and starts all over again lol
Old 06-17-2011, 11:22 AM
Badazz 97 TA's Avatar
whell win u changed da button did u lock da skrewz in place whit lok tite? and wat da hEck is a button?
Old 06-17-2011, 11:35 AM
speedZ28's Avatar
Bug. Button u no wat I meant! Yes they were lock tited! Lol
Old 06-18-2011, 12:53 AM
speedZ28's Avatar
So ok I triple check the wires and replaced the rotary bug and cap and mad Damn sure thay were all snaped on correctely!!! I just put new plugs in and didn't run them but maybe 10 miles after my motor build !! So i guess the nexted step is to buy new plugs and have icm and coil checked rite or am I missing something? Would a vacuum leak cause a miss over 5000 rpm now since I change all the stuff out its a hit and miss now between 1st and 2nd does it maybe once or twice win trany shifts between 2nd and 3rd that's win it really starts doin it if u guys have nemore suggestions let me no thanks!!!
Old 06-18-2011, 01:01 PM
speedZ28's Avatar
Nemore suggestions
Old 06-18-2011, 02:20 PM
gregrob's Avatar
Yeah, stop smoking weed.
Old 06-18-2011, 02:40 PM
speedZ28's Avatar
Why u got be, a f'in smartass
Quick Reply: missing after 5000 rpms!!!
