Puck's SR 383 build: Results for PTV and PR length
Old 06-16-2011, 04:47 PM
Puck's Avatar
Default Puck's SR 383 build: Results for PTV and PR length
Got my new PR length tool in yesterday (since my old one was too short), and got to measure my PTV and PR length today.
Even with 0-decked block, milled heads, large valves, high lift, and a decent duration SR cam I've got ton's of PTV clearance: Measured .075" INT and .1" EXH...well above the minimum recommended . I've seen people run as tight as .030" without issue. That is with just the damper spring installed, so I will get another .02" or so with the real spring. I was expecting to have a lot less.
Pushrods measured 7.88" end to end, so I'll be calling trend to order some 3/8 .135 thick-walled pushrods in the proper length tomorrow (7.85? 7.875?).
Old 06-16-2011, 04:54 PM
SS MPSTR's Avatar
Making progress!
Old 06-16-2011, 05:28 PM
Puck's Avatar
Originally Posted by SS MPSTR
Making progress!
2 1/2? 3 years?
Slow and Steady wins the race .
Old 06-16-2011, 06:13 PM
SS MPSTR's Avatar
Originally Posted by Puck
2 1/2? 3 years?
Eh, it took me 4 years to build my Chevelle. It's just time and a ton of money!
Old 06-16-2011, 06:44 PM
96MeRcEnArY's Avatar
Money being the key word!!!
Old 06-16-2011, 06:48 PM
quik95lt1's Avatar
wow thats some nice PTV clearance.......hell im under .040 on the intake and .050 on the exhaust lol.......
looking good buddy!!! get er done!!!
Old 06-16-2011, 07:05 PM
joelster's Avatar
AWESOME!!!! What compression are you running?
Old 06-16-2011, 08:49 PM
Puck's Avatar
Only 12:1...
I wanted more, but with these big heads its hard to get good CR without dome pistons. I milled the heads down (and lost 7ccs and a few CFMs in the process), am running the .026 VR gasket, and block is zero decked.
Once I get the tool to remove springs with heads installed(I only have the clamp style one for heads off the car), I can tq down the heads and once the PRs come in I can throw on the intake...its going to be a complete engine finally after 3 years . Timing cover, Oil pump, pickup, and pan are all installed already.
Not quite done yet though..."To Do" list is currently some fuel lines, an AFPR, a hub/damper, and a computer system - going with Wickeds Opti-Trigger setup using a trimmed factory harness. Hopefully he can get me some more RPMs out of it .
Old 06-16-2011, 09:11 PM
Village Troll
SS RRR's Avatar
What lifters are you going to be running?
Old 06-16-2011, 09:24 PM
Puck's Avatar
The new style Pressure fed COMP Endure-X. 888-16's IIRC. They are now tool steel axles, extra oil groove, and pressure fed...unlike the older style COMP SR lifters.
LE recommended them for me. I think FFB put something like 8000 street/cruising miles on his without issue, and knowledgeable builders on sites like speedtalk use them as well.
Old 06-16-2011, 09:43 PM
Village Troll
SS RRR's Avatar
Ah... so the lifter body is about the same length as stock, but still link bar style?
Old 06-16-2011, 10:13 PM
Puck's Avatar
I think they are slightly taller then stock, in a link bar style.
Haven't put one side by side to a stocker.
Old 06-17-2011, 02:16 AM
Wicked94Z's Avatar
888 is +.300
Old 06-17-2011, 08:27 AM
Village Troll
SS RRR's Avatar
I'm wondering if you can still put them in/take them out with the heads on? That is the one thing I hate about the Iskys I have is the heads must come off...
Old 06-17-2011, 09:57 AM
Puck's Avatar
Nope, have to pull the heads .
Old 06-17-2011, 10:01 AM
97 6speed z's Avatar
Only 12:1...
With zero deck and the .026" VR head gasket, on a high reving solid roller engine .............. aren't you worried about "rod stretch" and possible piston to cylinder head clearence issues?
Old 06-17-2011, 11:01 AM
Puck's Avatar
Nope .
I am definitely on the tighter side, but I think it will be fine. NA SBCs love sub-.040 quench.
Bottom end is half filled and has forged H-beams with huge L-19 rod bolts - I shouldn't have a problem spinning to ~7500rpms with my modest all motor power goals.
Old 06-17-2011, 12:14 PM
Thumbs up
Nope .
Which brings up my next question: Using those huge L-19 rod bolts with that 3.750" stroke crank ............ did you break into any water jackets during clearencing of the block? I know you half filled it, but, did you "hit water" during clearencing which required the half fill, or did everything "swing" without any water jacket intrusion?
Old 06-17-2011, 12:47 PM
quik95lt1's Avatar
i run the shorty HIPPO SR Morels in mine..........they jusssstttt squeak by with the heads on........
Nope .
yep nothing wrong with it but i wouldn't go any closer.......im running .030 on mine with an oliver billet and ARP WSB bolts revving 8000 plus with no issues.....
Old 06-17-2011, 03:46 PM
gregrob's Avatar
Lol its not like he's using aluminum rods
Quick Reply: Puck's SR 383 build: Results for PTV and PR length
