Steam Pipe A/C Seals
Old 06-18-2011, 10:54 PM
GMC5.3's Avatar
Default Steam Pipe A/C Seals
Ive searched that people buy these a/c seals and i just wanted to double check that its the right package, im still having a leak through my steam pipe on my driver side. Also i broke my oil pressure sending unit, is this something i have to get through the dealer, autozone couldnt cross gm numbers on it. Thanks
Old 06-18-2011, 10:59 PM
fex77k's Avatar
I found a A/C washer that had a metal ring on the outside with a rubber washer on the inside. They were really cheap too. The oil pressure sender unit can be bought anywhere. It might be located on the parts warehouse computer as a oil pressure switch, since it is used on the dash gauge and not a sensor for the PCM.
Old 06-19-2011, 03:49 AM
gregrob's Avatar
They are called stat-o-seal washers... try a local big rig shop.
Old 06-19-2011, 08:21 AM
That's MISTER MODERATOR
Paul Bell's Avatar
No type of regular O-Ring seal will stay under the bolt head when you tighten it down, they will not work.
The other guys are right, Stat-o-Seal washers are what you want:
Old 06-19-2011, 06:12 PM
97Z28SS's Avatar
I couldn't find those #$@&ing washers either so I converted mine to AN fittings and braided lines.
Old 06-19-2011, 06:15 PM
Wicked94Z's Avatar
napa has em for oil pan drain plugs... like 1.30 a piece or something
Old 06-19-2011, 06:17 PM
Paul Bell's Avatar
Yeah, they can be tough to find. They're often considered air conditioning components. I'll bet that's how the OP ended up with A/C O-Rings.
They're also used as oil cooler piping seals.
Old 06-19-2011, 06:25 PM
Paul Bell's Avatar
Here's a bunch:
http://www.autozone.com/autozone/acc...6?viewAll=true
Old 06-19-2011, 11:42 PM
GMC5.3's Avatar
you guys are bad a$$ thanks, last chance before i go to a junk yard for a new steam pipe
Old 06-20-2011, 04:27 PM
Go On 3's Avatar
i found them at advanced auto and autozone by the oil pan drain plugs each store only had 2 in stock, they were pretty cheep
Old 06-20-2011, 04:43 PM
md88's Avatar
Autozone has a seal kit that has the washers and all the O-rings for $6.99. It's part number MT2541. My local AZ had it in stock.
Old 06-21-2011, 12:15 PM
GMC5.3's Avatar
Thanks for all the replies, check this out i think i may have found my problem
Look at the left bolt, the thread is somewhat smashed in, would this cause my leak along with the washer? Keep in mind i did have the right seal on before i bought the stupid a/c washers.
Quick Reply: Steam Pipe A/C Seals
