Need help with Tunerpro RT
I've been trying to scan codes on my Z/28 with this software and I keep on having the same issue. I get readings on various engine data (i.e. ignition voltage, o2 readings, oil temp, etc.) but for whatever reason I'm unable to pull any codes. If anyone can help me shed some light on something I might be missing, I'd greatly appreciate it. TIA!
it doesnt work with the data stream on my 94 z im using a usb aldl cable no serial converter. i only use tunerpro to read the bin after ive scanned it with winflash and then I can make changes in tuner pro. otherwise i use efilive to pull codes or freescan
Thanks, hoursetraitor. I have free scan but it doesn't ever wanna work right. It's been doing funky stuff, like for instance every time I'd try to adjust the port on free scan, an error box would pop up saying, another one comes up right after that saying something about "abnormal termination" and then the program just closes itself. Maybe I should try to re-download it?
What about the efilive one you speak of? I've never heard of it, is it a free one like free scan?
