What thread sealer for the head bolts?
Old 06-22-2011, 05:44 PM
Big Al's Avatar
Default What thread sealer for the head bolts?
What ever is on mine is white and hard to get off
Al 95 Z28 going back together
Old 06-22-2011, 06:04 PM
riceburnerZ28's Avatar
Permatex thread sealant is what I've used for years and it's white.
Old 06-22-2011, 08:46 PM
flyinZ's Avatar
Yep, Loctite makes something similar, thread sealant, white.
Old 06-22-2011, 08:56 PM
speed_demon24's Avatar
I used permatex #2.
Old 06-22-2011, 11:39 PM
Camaro350Z28's Avatar
sounds like your chick is broken lol
on a side note theres a recent thread with pics of thread sealer. just any thread sealer will probably do
Old 06-23-2011, 07:55 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Stay away from the moly and/or Teflon based thread "sealers" on the market. They can wash away when exposed to the environment of an engine's internals.
A nice sticky Permatex gasket goop will work great and stay put.
Old 06-23-2011, 09:45 AM
Gojira94's Avatar
NOTHING BUT Permatex 59235. You'll need the 50ml tube- plenty to do the head and intake bolts with some left over. The little tubes you'll need 7-8 of...
Old 06-23-2011, 09:47 AM
Internet Mechanic
BlackScreaminMachine's Avatar
I have always used Black RTV and that was with ARP bolts. You can run a tap and due on the block and bolts if your reusing. Make sure the bolts are not TTY
Old 06-23-2011, 12:20 PM
Paul Bell's Avatar
HMMM. Permatex 59235 "contains PTFE." This is Teflon.
Old 06-23-2011, 02:00 PM
food nd cars's Avatar
What is the proper technique when applying? Do you use it on all the head bolts?
Old 06-23-2011, 02:34 PM
TwoFast4Lv's Avatar
I use ARP sealer on the threads and ARP lube on the washers and heads. never had a leak in 14 years
Old 06-23-2011, 11:01 PM
Gojira94's Avatar
No evil in that. Don't get hung up on the non-friction aspect of the Teflon ingredient among many others. It's appropriate in both the Permatex and ARP formulas because of its non-reactive properties in corrosive chemical environments. Like what happens to oil in the presence of crankcase / exhaust gases...
ARP 100-9904 Sealant Thread Sealer is also Teflon-inclusive. And this guy has no problems with it over the last 14 years.
Old 06-24-2011, 12:23 AM
gregrob's Avatar
Stay away from the moly and/or Teflon based thread "sealers" on the market. The can wash away when exposed to the environment of an engine's internals.
WHAT??
You want HI TEMP... Teflon is fine
Old 06-24-2011, 12:40 AM
how much are you supposed to put??
Old 06-24-2011, 01:04 AM
gregrob's Avatar
Fill the threads...
Old 06-24-2011, 07:12 AM
Paul Bell's Avatar
Seriously guys, this has been discussed over and over.
Permatex Indian Head used to be the sealer of choice but High Tack is better. It's impervious to oils, fuels, coolants and temperature cycles. Years down the road, pull the head bolts/studs and High Tack is still coating the threads.
Quick Reply: What thread sealer for the head bolts?
