how to replace a bad cat....
Old 06-23-2011, 07:19 PM
FocusVince's Avatar
Default how to replace a bad cat....
As the title implies the cat converter on my 93 Z28 is bad, its very rattly, I get terrible gas millage, not getting any high end power, and the exhaust is cold. So my question is how do you remove the old one and install a new one? There is a magnaflow cat at advance auto parts I'm looking at and if it has the same inlet and outlet size I'll use that one. Do you saw the old one off or is it clamped on?
THanks in advance
Old 06-23-2011, 07:24 PM
white ghost's Avatar
The factory cat is welded on. Do you require a cat? If not spend a few extra dollars and get an off-road y-pipe that bolts to the factory manifolds. Or put a set of headers.
Old 06-23-2011, 07:29 PM
IronOutlaw's Avatar
The front is welded and the rear is bolted on. The magnaflow cat is supposed to be a quality unit. For free you can gut it out. It will drone a little but it would get you by until you decide what to do.
Old 06-23-2011, 08:11 PM
FocusVince's Avatar
I live in NC so I'm required to have a cat. Is there a way to clamp the new cat in where the original was welded in?
Old 06-23-2011, 08:31 PM
Really? Both my cats were welded on both ends in the middle of the y pipe.
Old 06-23-2011, 08:52 PM
IronOutlaw's Avatar
His car is a 93. 93, 94, and some 95 models have one cat at the end of the y pipe. Its a completly different setup than the two cat cars.
Old 06-23-2011, 09:55 PM
Oh. Ok. Didn't know that. Cool.
Quick Reply: how to replace a bad cat....
