help!!!!!
Old 06-29-2011, 07:28 PM
white ghost's Avatar
Default help!!!!!
I need help from the gurus. I have a clear, odor less oily substance coming from the rear of my engine.
I would think its motor oil, but I started my car for a few minutes and when I turned it off and looked under it and it looked like I lost a quart. But my oil level if fine........so confused!!!
Old 06-29-2011, 07:47 PM
wreckwriter's Avatar
Sure its not brake fluid?
Old 06-29-2011, 08:02 PM
It'llrun's Avatar
This time of year, many people have an abundance of H2O dripping and if it gets dirty along the way, it may appear to be oily... specially if there's any oil leaking around the engine compartment. Next test for me would be doing exactly what you did, but with the A/C turned off first.
Old 06-29-2011, 08:31 PM
Ok. Brake fluid is a possibility that I didn't consider. Definitely not condensation air was not on and it was like extra virgin olive oil is what it reminded me of.
Old 06-29-2011, 08:32 PM
camar0corey's Avatar
Well you said odorless, so I'm going to guess its not fuel, but given its location, it could be fuel?
Old 06-29-2011, 08:41 PM
At first I thought maybe I had sprung a leak in a f something because I was starting to slowly clean the engine bay and removed the air intake trying to source a small oil leak on the front of the motor. Fired the car up before I started cleaning and my wife interrupted my cleaning to run to the store and I saw it as I was backing out.
Old 06-29-2011, 09:27 PM
It'llrun's Avatar
If it lost a qt of brake fluid, surely you'd have noticed as soon as you backed from the drive and applied the brakes.
Not much is left. Coolant(shouldn't be clear), WW fluid(not often clear and never oily), fuel(not odorless)... maybe you spilled something.
The only things left are A/C condensation(ruled out), engine oil and transmission fluid, either of which could appear clear and even odorless in very light quantities.
Blinker fluid?
Old 06-29-2011, 09:48 PM
TheHeadFL's Avatar
The feeling of brake fluid on your skin is unmistakable. Most brake fluid is hygroscopic meaning it will leech the moisture right out of anything that touches it. Like, say, your skin.
Old 06-29-2011, 10:12 PM
nitrous2fast's Avatar
power steering fluid.
Old 06-29-2011, 10:15 PM
I drove my truck to the store. Car was parked.
Old 06-29-2011, 10:20 PM
Im really leaning toward it being my hyper-drive fluid. Its what allows me to obtain warp speed before the first light year passes. Lol.
Old 06-29-2011, 10:27 PM
IronOutlaw's Avatar
It must just be that time of the month again.
Old 06-29-2011, 10:30 PM
Lmao. Yea ole bitch gets pissy. Lol.
Quick Reply: help!!!!!
