AC compressor issue
AC compressor issue
well i live in florida and absolutely HATE the heat, so i kind of need it, so just taking the compressor and the accesories out isnt an option. ive ran dye through the system, and the compressor itself is leaking causing me to have a total lack of cold air. i took it to a shop and got a quote, its like 445 for the kit, 722 total including labor... SO, i want to know if this job is possible to do it in your garage. i know itll take about 3-5 hours.
or is there any simple fixes i can get to keep the AC cold till i move in the next month or so?
I replaced my own AC compressor. It is very doable and not very difficult.
But there is a catch. You don't just fill the system...
First of all, if your old compressor is giving up the ghost, it may have littered your system with metal shavings, etc. You'd want to change out your expansion valve. You'd also want to change your accumulator since your system is going to be open to the air, since it will absorb moisture.
Then, you need to pull vacuum on the whole system to make sure you get out all the air/moisture, THEN you need to fill the whole system and make sure to use a proper pressure gauge set that can measure pressure on both the high and low side.
I did all of this myself but I didn't replace the expansion valve and had to end up doing it again later, and getting the proper gauges and vacuum pump and such wasn't worth it in the end.
my system works, air blows through the vents, i did get it charged and flushed, the gauges work, well turn, and when it did work the total of 5 hrs it did it worked excellent
Harbor freight. Or Autozone actually. They aren't super expensive but it adds up. You also need a vacuum pump, that is the more pricey item. You can get one that runs off of a shop air compressor (like an air tool), but that doesn't pull as much vacuum as what the pros use. We were only able to get like 25 inches. You really want to pull like 30-40 from what I've heard.
well im going to call around tomorrow to different shops and stuff see what they will charge for the work, may also call where i got the car maybe they can give me a hook up, if not im def going to consider doing it myself, cant stand sweating in my car anymore
BTW-
GM Expansion valve (95-97), pn 52477944
Autozone sells accumulators...
You also need some misc o-rings and some compressor lubricant.
As I understand it, Autozone may be able to lend-a-tool the vacuum pump and manifold guages.
He says it is leaking from the compressor so I am guessing it is probably leaking at the interface between the hard line and the compressor itself. I want to say (from memory) that its held on there by a bolt and there are 2 o-rings. If you're going to bother with it though, might as well do it right, IMO. (Replace compressor, accumulator, o-rings, vacuum it out, fill, etc.)
