'93 alternator upgrade?
Old 07-06-2011, 12:29 PM
VinR1's Avatar
Default '93 alternator upgrade?
I've gotten mixed search results but I'm pretty sure my '93 came stock with a 105amp alternator and the 94+'s came with a 140...? If this is correct, can I just swap out mine with a newer one? ...or is the wiring/harness different?
My current one is fine but driving at night w/ headlights on, a/c blowing, and radio on, the needle sits at the very top of the yellow area on the gauge
TIA
Old 07-06-2011, 12:53 PM
Moderator
BizZzatch350's Avatar
I didn't think the stock was 105, more like 124? I have a 97 LT1 alternator on mine, the power cable worked fine, I believe the plug did too, I have an EFI 24X harness now but I ran the 97 alternator back when it had the 93 harness also. It's been a while.
Old 07-06-2011, 02:55 PM
madhatter's Avatar
Even if it is 105a it shoudl still be enough to power everything. Try making new grounds and upgrade the wiring. 9/10 that will fix everything.
Old 07-06-2011, 03:17 PM
VinR1's Avatar
you're right, 124amp
Old 07-06-2011, 03:43 PM
djjab57's Avatar
My 94 has the 124 amp, I always wanted to go to the 140, with everything on it sits on top of the red and dips down sometimes. I have had the car for 7-8 years and its always done it
Old 07-06-2011, 04:24 PM
whytryz28's Avatar
Im using the 140 amp alternator from the newer LT1 engine, nothing to change besides the alt.
Also do the Big 3 wire mod, well worth it.
Old 07-06-2011, 04:34 PM
djjab57's Avatar
Originally Posted by whytryz28
I'm using the 140 amp alternator from the newer LT1 engine, nothing to change besides the alt.
How did you swap ? one is one wire the other is a 2 wire connector
Old 07-06-2011, 04:44 PM
whytryz28's Avatar
Really? lol I just threw it in, hooked up the stock 93 connectors and it worked fine.
Old 07-06-2011, 05:22 PM
djjab57's Avatar
LOL yea thats the reason I haven't done it yet. I need to know how everyone was switching from one wire to 2
Old 07-06-2011, 05:49 PM
djjab57's Avatar
Or I should say one is a square connector and one is round
Old 07-06-2011, 06:12 PM
whytryz28's Avatar
My alternator is from a Late 94' model Z28, same connector as the 93-early 94 but 140amps. Just get the alternator for a 94 z28 but it has to have the threaded stud in the back.
Old 07-06-2011, 06:27 PM
djjab57's Avatar
OK I have the early 94
Old 07-14-2011, 08:46 PM
DisturbedTA's Avatar
mine is a 95 its a square one wire plug too
Quick Reply: '93 alternator upgrade?
