Tcc power feed?
Old 07-06-2011, 01:02 PM
henry172's Avatar
Default Tcc power feed?
I am hooking up a 96 a4 harness in my 97 m6 trans am; I have everything correct, but I am not sure about the Tcc power feed on the c230 plug. I have a wire from the brake wired to a relay that will either put out 12v when the brake is not pressed then nothing when the brake is on or no power until the brake is pressed. So is the wire on pin H on the c230 plug supposed to be hot when the brake is not pressed or is it supposed to only have 12v when the brake is pressed? http://shbox.com/1/harness_connector_faces.htm
Old 07-06-2011, 05:26 PM
shbox's Avatar
C230 H should go open when the brake is depressed. Otherwise it has 12v on it when the key is ON.
Old 07-07-2011, 12:21 AM
henry172's Avatar
Thank you I just finished installing the harness. Now I just need to install the ltcc box and I will finally be able to drive the car again.
Quick Reply: Tcc power feed?
