oil/trans temp gauged installed
Old 07-07-2011, 09:42 PM
BL96TA's Avatar
Default oil/trans temp gauged installed
Just wanted to share some pics of my oil/trans temp gauge install. Thank you to this board for giving me the information i needed to install my sensors for the oil temp in the block and trans temp in the trans to provide a clean and simple installation without having to drill any holes in either pan.
Attached Thumbnails oil/trans temp gauged installed-img_1348.jpg   oil/trans temp gauged installed-img_1349.jpg   oil/trans temp gauged installed-img_1350.jpg   oil/trans temp gauged installed-img_1358.jpg   oil/trans temp gauged installed-img_1360.jpg
Old 07-07-2011, 09:55 PM
BL96TA's Avatar
here is the post that helped me install my oil/trans temp gauge https://ls1tech.com/forums/lt1-lt4-m...emp-gauge.html
Thanks again ls1tech
Old 01-18-2012, 07:41 PM
vader96's Avatar
where did you tap in for the lighting on your guages...i cant find where to tap from
Old 01-21-2012, 05:10 PM
BL96TA's Avatar
My fuses inside the car. Ill take a pic and pos it up for you some time tomorrow.
Old 01-22-2012, 04:09 PM
BL96TA's Avatar
blue wire is for the lights and the red is power.
Attached Thumbnails oil/trans temp gauged installed-img_2081.jpg
Old 01-22-2012, 04:16 PM
riceburnerZ28's Avatar
Glad it turned out well for you.
Old 01-22-2012, 05:31 PM
vader96's Avatar
thanks for replying man...i couldnt open that link can you try one more time
Old 01-22-2012, 05:45 PM
BL96TA's Avatar
No problem, I can't see the pics in this thread, don't know if your having the same problem. Here is my cardomain which has the pic I tried to post here. http://www.cardomain.com/usernew/gar...u=2&id=3897599
Old 01-22-2012, 07:27 PM
blackjack325's Avatar
repost pics!!! i wanna do this too!!
Quick Reply: oil/trans temp gauged installed
