Possible bad injector
Old 07-07-2011, 11:09 PM
henry172's Avatar
Default Possible bad injector
I just finished installing me ltcc ignition and I have a miss and hard start; it will start easy if I start it seconds after it running, if I try to start it more than a few seconds after it has ran it starts had and only starts if I keep the throttle part way down. I pulled the coil wires on each cylinder and only cylinder 2 shows no difference when the car is running, I checked for spark and it has spark; I tried to feel the injector as it was running and it seems like it is not working. The ltcc box has a solid green light on so I believe the ignition is fine. What should I do next, they are ford svo 30# injectors.
Old 07-07-2011, 11:43 PM
jasonisdn's Avatar
move that injector to another location and see if the problem follows the injector. if it does thats your issue. if not check your grounds for that coil.
Old 07-07-2011, 11:49 PM
henry172's Avatar
^ I am going to give that a try tomorrow; I hope it is the injector then I it will be a easy fix.
