Oil cooler Delete How to plug water pump.
I deleted my oil cooler and plugged the oil cooler coolant hose with a bolt. But the other day the 90 degree fitting fell out of my water pump causing me to loose all my coolant.
The fittings are just pressed in and now its a pretty loose press fit.
What are you guys using to plugs those two holes.
