machine shop screwy???
Old 07-12-2011, 12:31 PM
97badass's Avatar
Default machine shop screwy???
i dropped my shortblock off to be bored .030 with speed pro forged pistons clevite h bearings arp main studs and arp pro rod bolts... he told me today the total bill would be $2115!!!!!!
he said he has to use a special race series piston because of my cam numbers... sounds like total bs to me?
Old 07-12-2011, 12:33 PM
Village Troll
SS RRR's Avatar
What are the cam specs?
Old 07-12-2011, 12:38 PM
97badass's Avatar
226/234 .565/.565 109 lsa
Old 07-12-2011, 12:41 PM
ahritchie's Avatar
You didn't get a quote on the work before you dropped it off? Terrible idea. I just picked up a fully machined all forged 383 shortblock for less than what they are asking for JUST machining...I be pretty ******* pissed if I was you. Sounds like they are trying to pull a fast one on you.
Old 07-12-2011, 12:45 PM
ahritchie's Avatar
My cam is bigger than than that (lunati voodoo 60122) and I got a COMPLETE forged 383 shortblock for less than what they are asking for just machine work....
95 TA - The Beast's Avatar
Now, you need to specify, is that including pistons, rings, bearings, rod reconditioning w/new bolts, machining and assembly? (plus you didn't specify if they did a line hone, deck the block, etc, so I will assume all the above)
If it is all the above that is not overpriced...
No idea what they are talking about "race series piston", but they may be referring to the fact they used forged pistons...
Old 07-12-2011, 12:48 PM
97badass's Avatar
im beyond pissed! and he knows it, im not as dumb as i guess he thought i was, so its going to a different machine shop that i have dealt with before... just figured i would try this guy bc he built my buddys 5.0 mod motor and it runs great. but he isnt building mine at least not for that price, hell not even for half of it! the parts i priced through summit was 647.xx which is less than what he told me just for speed pro "special race pistons"
Old 07-12-2011, 12:49 PM
Wow, would like to know the hookup you got to get a "quality" forged 383 for less than $2100...
Hell, an Eagle or Scat forged rotating assembly runs $1200+ including forged pistons... Then you add in decking the block, bore/hone the cylinders, new cam bearings, cleanup the block, maybe a line bore/hone if needed... Then add in ARP main studs and all the other extras...
Honestly, I don't know if I would trust much to a $2100 "forged" 383 shortblock... Doesn't cost a ton more for a quality build, but it most certainly will cost more...
Old 07-12-2011, 12:51 PM
97badass's Avatar
yes resize rods for bolts install cam bearings line hone and balance and bore, he said the most expensive part was the pistons, not the machine work...
Old 07-12-2011, 12:58 PM
ahritchie's Avatar
It's called the classified section of the website....check out my thread "budget bulletproof bottom end" and you will see no corners were cut...all ohio crankshaft and keith black internals. Don't hate cause I got a better deal than others here....its called smart shopping! Seller moved on to a 6.0LS so his loss is my gain
Old 07-12-2011, 01:01 PM
RamAir95TA's Avatar
Apples to oranges dude. You're comparing a shortblock you picked up off the internet to a guy having the assembly and machining done.
ahritchie's Avatar
LOL>>here ya go buddy
https://ls1tech.com/forums/parts-cla...lock-sale.html
Old 07-12-2011, 01:03 PM
ahritchie's Avatar
My point is it still seems WAY high. That's all
Old 07-12-2011, 01:47 PM
Big Al's Avatar
Got it from?
Al 95 Z28, It's alive!
Old 07-12-2011, 01:51 PM
boostedlt1's Avatar
that's almost exactly what i paid for all the machine work on my block. that's with me assembling everything myself.
parts alone were $1k of it though
Old 07-12-2011, 01:58 PM
Village Troll
SS RRR's Avatar
'snot
Not uncommon to pay around 5K or more for a complete shortblock after all is said and done.
Old 07-12-2011, 02:01 PM
ahritchie's Avatar
Originally Posted by Big Al
Got it from?
Fellow forum member: 93Z2871805 ...Nice guy to deal with
Old 07-12-2011, 02:02 PM
gregrob's Avatar
You gotta pay to play
Old 07-12-2011, 02:09 PM
ahritchie's Avatar
Originally Posted by SS RRR
'snot
Holy ****!....I was under the impression you could get the machine work done for around $1000 +/-; oh well this just re-affirms I made the right decision for MY BUDGET and got a complete forged stroker shortblock machined and assembled. I'm well aware that quality forged internals are minimum about $1400 themselves; not to mention cam, lifters, oil pump, oil pan, ect, ect, and machining. Yall just made my day because I just saved a shitload of money on my LT1 build Sorry OP, good luck with the other machine shop.
Old 07-12-2011, 02:12 PM
gregrob's Avatar
You saved a load of money because you get CHEAP internals and unknown machine work.
OP my machine work was $1700 just for a 355 w splayed mains. That's quality work though line hone bore deck etc etc.
That was only them supplying bearings and main studs.
