valves ?
Old 07-14-2011, 12:15 AM
1hotlt1's Avatar
Default valves ?
All make it short... what type of valves should I use for stock lt1 heads? + am using nitrous... thanks Guy's.
Old 07-14-2011, 02:08 AM
food nd cars's Avatar
valves shouldn't be a main concern unless you are planning on using a massive shot.
I would be more concerned with you bottom end. Your stock rod bolts, pistons, rings, even head gasket.. Also if its for a build make sure your cam goes well with nitrous and that your fuel delivery is on par as well as your tuning.
Old 07-14-2011, 07:44 AM
Mystery Bird's Avatar
You can get away with 2.0 intake and 1.55 exhaust on the stock seats with some grinding. I used Manley race flow.
Old 07-14-2011, 07:52 AM
RamAir95TA's Avatar
Stock.
